I do apologies that model is not the right size i forgot to downscale it and then save it.
what i had in the screenshot was the same thing but i rescaled the x-axis to 250mm and rotated it 45° so that it would fit on the print bed.
Edited by JOMS
Edited by JOMS
Sorry I didn't check the STL but I think the walls are just a little too thin. Try setting "horizontal expansion" to 1mm just as a quick test and then playing with that.
Or alternatively, try setting "line width" to smaller and smaller values until it slices. It's okay to have line width at 75% of nozzle size - print quality won't suffer much. So 0.3mm line width for a 0.4mm nozzle.
That didnt seem to work either.
Thank you for the suggestions though.
It does not work because the model has no wall thickness at all. It's a non-manifold geometry and therefor cannot exist in the so-called "real world". 🙂
I don't know the software you use, but you should read about how to create manifold geometry for 3D-printing.
For example:
https://www.sculpteo.com/en/3d-learning-hub/create-3d-file/fix-non-manifold-geometry/
I see, thank you ill give that a try.
One is your canoe and one is mine. Can you tell which is which?
Attached is the repaired model. I like Service.netfabb.com for model repair. They can even float boats and it's free.
Oh wow thank you this is great.😄
Mari 38
Try by activating "print thin walls" under Shell... if that doesn't work, share the STL-file so we can take a look at it...
JOMS 1
Unfortunately activating "print thin walls" didn't work.
Here is the file.
Canoo.stl
