40 minutes ago, nizam87 said:However I found that ASA is quite weak in the layer height direction which is not suitable for my application i.e. to hold weight in that direction.
The weakness should never be along layer lines like this. If it is then you have bad layer adhesion. This is because as you print a new layer over an old layer, the new layer is not melting the old layer enough to get a good bond.
You fix this by lowering the fan speed. As low as possible. I'd try 1% and start from there. Also consider covering the top of your S5 with a large box. Ideal air temp is around 35C to 40C (the highest safe temperature - you won't damage any components with air at 40C).
You can play with the fan speed in the TUNE menu but you want it as low as possible but still turning.
You don't have to cover the top of the printer - slowing down the fan (possibly to 0%) will help the strength a LOT.
gr5 2,225
I haven't printed with ASA so I'm not sure if it gets any better than this. PLA is just such a wonderful material if you are looking for good looking prints.
I've heard people call those "zits". I don't care about them much so I haven't paid too much attention but they happen when the pressure in the nozzle is high and some filament squirts out sideways in the cracks.
I'd try cutting the speed by 2X to see what happens and play with it from there. I think you can do that live in the TUNE menu. Also in Cura make all your speed settings the same. By default Cura prints faster in the infill and slower on the outer skin so you get overpressure when it slows down (too much pressure in the print head for a few seconds until it equalizes again).
Let us know what you learn.
Everything is a tradeoff. If you want prettier walls you can do it but it will probably cost you in print time.
nizam87 0
Thanks for your help gr5. yes I did make the speed lower and same across and the result is as attached.
However I found that ASA is quite weak in the layer height direction which is not suitable for my application i.e. to hold weight in that direction. Now testing with Polymax PC which is claimed to have better mech prop.
I would like to get your advice on two things:
1. Line width - Why the preset profile tend to use different values of line width? will this have significant effect on the quality of the print? I usually use same line width for other printers.
2. Equalize Filament Flow - Is the printer smart enough to optimize this variable as it claimed? Do you normally turn it on or off?
