I've done this screw with a Monoprice Voxel on default settings, and it's flawless, which is why I was interested in what could be causing it this time with the 2+ connect.
Slowing the print down to 20mm helped eliminate it as much as I could, which I wish wasn't the only solution, as it turns any simple model with an overhang into a half day print. Thank you though.
geert_2 558
Such steep overhangs curling up is normal. In my experience, printing cool and in thick layers helps a little bit, but does not eliminate it. More than half of the extruded sausage is printed in the air and has no support to stick to. So it sags when extruded, and then it curls up when cooling...
