Hi Balshaj,
see this official instructions:
https://support.ultimaker.com/hc/en-us/articles/360011474120-Lift-switch-calibration
or, if you prefer watching to reading, a good video tutorial, privided by @fbrc8-erin:
Regards
Edited by Enigma_M4added information
2
Torgeir 250
Hi @Balshaj,
Welcome in here!
First question, if you move the switch handle by hand, -does it go to both position. Can nozzle 2 can stay in fully up and down position?
If the first question is answered No, the nozzle lift mechanism has failed. (This is a known issue.)
If the first question is yes, you'll need to re calibrate the nozzle switching procedure.
(Second question, -does not the automatic switch procedure go as it should?)
Re calibration of this switching "might" sometimes be a little tricky, but when you got it right it's really working well.
Let's see how this go.
Good luck
Thanks
Torgeir
Balshaj 1
Yes if i manually move the switch it retracts the nozzle and leaves it retracted until i flip switch again. the spring had popped out before but i put it back and there are no issues with the switch functioning correctly when used manually.
how do i re-calibrate the nozzle switching position....i didn't even know that was a thing!
(it does go to where it should , however it misses the notch and does not flip the switch.)
