The elephant foot is difficult and I'm not sure what causes it - possibly temperature issues, possibly other factors. As Robert suggests, the most common solution is to compensate in the CAD part. Also different people get different sized "feet" depending on many factors (layer height, temp, speed, fan) so it's hard to fix in Cura. Easier to fix in CAD.
The pillowing as Robert suggests is almost always caused by inadequate fan. Are both of your side fans working? Many Ultimakers came with disconnected side fans. Click "PRINT", choose and model, then quickly go into the TUNE menu and set the fan speed to 100%. As long as you stay in the tune menu the printer will not start printing. If the fans aren't working, try sliding up the black plastic mesh at the top of the head and checking the 3 fan connectors. The wires leading to the 3 fans are red and black.
As robert already said, pillowing can be reduced by thicker layers and also mitigated by having more top layers. But you already have 10 layers! I usually only do 4 and rarely see pillowing. I often don't even do infill (which helps support) and still don't usually see pillowing. So - maybe the fans are off? Also check that they are blowing and not sucking (that was a problem on a UM1 once but I don't think the UM2 fans are capable of spinning backwards).
IRobertI 497
The bubbles on the surface is called pillowing (at least I think that's what we've settled on hehe). It's mainly caused by a lack of cooling. What are your settings for the fans? Increasing the infill percentage may also help as it will give the top layer more support.
That the very first layer is sticking out a bit more is called the elephant foot and is caused by the first layer being squished a bit so that it becomes fatter than it should be. I've also noticed that a bed that is too hot makes it worse. I usually put a chamfer on the bottom surface to combat this. 0.5-1mm depending on the print is what I normally use. If you're running the default 70C for the bed I recommend lowering that temperature to 50-60C, I use 60C mostly.
edit: Also, I'd probably print that at 0.1mm instead as you don't really gain anything from the 0.06mm layers with such a basic shape. That should also help with the top surface as it will be easier for the filament to bridge over the infill.
