Android octoprint
Posted · Android octoprint
Did anyone try running octoprint on old android phone?
I was thinking about using my xiaomi mi a2 or huawei p20 lite to controll my UM2+.
As i need to use same usb port for data and chargingn I have to make custom OTG cable.
Before I start that project I want to make sure is this diagram safe for UM2+:
Left side would be type C or micro USB, right side type B for 3D printer and bottom type A for charging.
Is there anything I should worry about? I don't want to risk my printer, so any tips are welcome 🙂
    I don't think it is worth destroying MBO, but it is worth my time since I enjoy recycling 😄
    Pi 3 with PSU, SD card and camera is 100$ and my phone is laying around collecting dust...
    Ok, 100$ is a lot more than here in Austria. I bought the last Pi3 for 30$.
    But try it, I mean you have just connected the two data lines and ground, so I think you should be safe to not damage your board, but if it works is another question.
    I would choose to not connect the +5V to the printer-side of the cable (but only to the phone-side). There is nothing to be gained by powering the printer PCB of the UM2 via USB.
    Hi folks,
    I'll think there is a little misunderstanding here, as this question is about powering the phone (only) by using a phone charger. The black cross in the red wire (going to the printer), -meaning the wire is cut here and I'm assuming that the remaining of the red wire toward the printer is insulated/end caped.
    His intention is to use the phones data connection wires and the ground only.
    So the printers +5VDC at the printers USB port is not used.
    Thanks
    Torgeir
    Yes i would cut the red wire just like on the picture above. In that case only data and gnd would be connected to usb on UM. I would start the project without charger first anyway to see if it works.
