thanks @GregValiant for your reply ,yes you understand correct , I think the problem is that when we try to work both extruder T1 and T2 at same position in same layer then Cura doesn't allow us because of detection of interference(collision) of profiles of extruders so we have to find in documentation of Cura the file which perform this task and then we have to change, replace or place a new file there to stop this detection . but till now I am unable to figure it out.
Can you help me out @GregValiant or anyone ? I will be very thankfull for this
GregValiant 1,330
So the laser is extruder 3? Or is it extruder 2? I will assume it is extruder 2.
If extruder 1 deposits material and then extruder 2 (laser) is to come in to fuse material then I think the layers need to be "interleaved".
Layer:1 extrude with T1
Layer:1 fuse with T2
Layer:2 extrude with T1
Layer:2 fuse with T2
Etc.
Something like that? Cura would preview that as it would a gcode file created with objects printed "one at a time" which is correct but seems wrong because of multiple instances of each layer number.
The preview is layer-by-layer though the gcode is really line-by-line.
