If you used sketchup then here's a tutorial to fix your model:
https://i.materialise.com/blog/3d-printing-with-sketchup/
You can try one of these 3 repair services if this isn't your model.
Cura has an amazing plugin to test your model to see if something is wrong with it and can repair a very few of the many potential problems:
In the upper right corner of Cura click "marketplace" and make sure you are on the "plugins" tab and install "Mesh Tools". Then restart Cura. Now right click on your model, choose "mesh tools" and first choose
"check mesh", then "fix model normals" and "fix simple holes" to see if that helps. Cura doesn't fix most issues so...
netfabb free repair service is here (you have to create a free account first):
https://service.netfabb.com/login.php
Here's another service - drag and drop mesh repair service:
https://3d-print.jomatik.de/en/index.php
1
ahoeben 1,770
The model is "broken". It contains missing or extraneous faces, which confuse Cura. The polkadot pattern shows where the model has issues (ie: a lot of issues!). In addition to the missing or extraneous faces, the normals are broken (but those should not affect the slicing much). Some of the normals are inverted (causing the red faces on top).
craigachan 1
Thank you for your reply. Is there a tutorial or KB that will direct me how to fix this? I'm not sure where to start.
