Posted · Swagger api (REST API) doesn't work after firmware update
After last weeks firmware update the swagger commands are not working anymore?
What has changed. We have an API running with this and we can't connect anymore!
Does anybode has the same issues?
    He means the REST API.  I added to title.  For those that don't know, Swagger is a debugging tool to document and debug RESTful interfaces.
    @nallath - did anything change in the latest update related to the REST API?
    @ArnoG - are you absolutely sure you are using the printer the exact same way?  Maybe you need to get a new access ID? (I haven't tried the API so I don't remember exactly how the access works but seem to remember you have to get some kind of access token and you may need to do that again after the upgrade).  Maybe you checked some box differently in Swagger (I've done that - where it seems like "it was just working yesterday" but I forgot to (or accidentally) changed something without noticing.  Do you have a second printer so you can have one printer at the older version to be sure?
    It is possible to downgrade the firmware.
    • gr5 changed the title to Swagger api (REST API) doesn't work after firmware update
    @ArnoG I don't think we made a deliberate change to the REST API, but last weeks we released several firmware releases for different printers, so it helps when you provide more details like:
    - What printer model are you using?
    - What is the version that's failing for you?
    - Perhaps you remember the version that was working before?
