Hi @FrancisGS131, thank you for your post. Hopefully as an Ultimaker employee I am able to give you a warm welcome! What filaments do you have installed in the material station? Do they all give you issues or just a select few? When the decoupler is obstructed you should get an error message: ER52. Are you getting any error messages?
Do you have the flow sensor enabled on your Ultimaker S5?
And finally, I'll give the support team a heads up regarding your ticket.
2
Carla_Birch 116
I don't own the material station, but have you give just using the S5 without the material station for a print a try? If all prints fine than you can be sure its then the material station, if you are still unable to print then the problem could be something other than the material station.
I'm personally someone who likes to remove factors from a problem so you can close in on the real problem faster, so doing the above can half the number of problems it might be.
UlrichC-DE 122
Hello
Unfortunately, I can't welcome you as warmly as an Ultimaker employee would.
It's the weekend, etc.
If the printer does not extrude, this is in most cases a clogged printhead.
This can happen quickly if, for example, the feeder is not set to the center position and a kind of cork forms over the print head. The phenomenon is then. At first it works, but during printing it starts to clog.
Another thing is that it is difficult to clean the print cores properly.
Not everything can be cleaned with hot-pull and cold-pull alone.
If there is still a piece of filament left above the print nozzle, the effect is the same.
Also, if the Bowden is too short, the problem comes.
I also had a lot of problems with my first material station back then.
If the filament supply to the first feeder is already disturbed, the only way is via the support.
I couldn't really help either, but here's the deal.
Many greetings
