Nope. trying to model a space using basic dimensions makes renderings look like a minecraft world.
I'll just reveng it when it arrives.
Air Handler arrived - took 8 days to arrive. An arduous experience, but that story is for another time (suffice it to say I'll NEVER deal with a shipper again that insists on FedEx - direct signature required) Installation was easy BUT I have leftover parts that were not mentioned in the instructions. Anyone know what these are for?
The yellow parts are needed if you want to remove the AirManager. And the screws are to mount an exhaust pipe to direct the exhaust air outside. There is also a printed part needed to do so and as far as I can remember you can request the STL from your reseller.
- 1
- 10 months later...
Where can I get 3d files of the air manager removal tools? I can't find mine. Thanks.
3 hours ago, guate6 said:Where can I get 3d files of the air manager removal tools? I can't find mine. Thanks.
You can use anything of roughly the same thickness. I've used folded up pieces of paper in the past.
@guate6 We've lost one of them so a colleague modelled it and then we found it again. Here's the model for it, untested though, so I can't guarantee it'll fit
EDIT: Uploaded rougher mesh model. What on earth is my colleague's mesh-export settings...
Edited by Nosybottle
SandervG 1,521
Hi, I don't think we've shared the drawings of the air manager, so I can't share those. But I could do some basic measurements if knowing the outer dimensions would be helpful?
