15 minutes ago, gr5 said:Did you go to the ultimaker.com/ER05 web page as suggested? There are some good ideas there.
If those don't pan out, maybe remove and re attach the connector to J6?
I guess I would use the below schematic and check out TP80. It should be 5V when the switch isn't triggered and 0V when the bed is down. If those voltages are correct then it's probably the "arduino" chip. Meaning you need another PCB.
The switch is working fine as far as I can tell--tested it with a multimeter, and the screw engages with it just fine.
Tested TP80 and I got 4.9V and 0V respectively. Is that close enough, or is the pcb bricked?
gr5 2,192
