GregValiant 1,364
The regular nozzle will work fine.
I think the main setting is the Flow% for ironing. If the layer went down with some slight over-extrusion and the Ironing flow is set too high then the nozzle can act like a bulldozer and push around the plastic that is already there and that will leave ridges. I would start with the default 5% and see how it looks.
Top Posters In This Topic
32
18
7
4
Popular Days
Dec 31
12
Jan 4
12
Dec 30
10
Dec 19
9
maggiolo72 32 posts
GregValiant 18 posts
gr5 7 posts
UlrichC-DE 4 posts
Popular Days
Dec 31 2021
Jan 4 2022
Dec 30 2021
Dec 19 2021
Popular Posts
geert_2
I haven't experimented with ironing yet, so I can't give advice on that. Concerning fighter jet cockpits: long ago, maybe 40-50 years, here in Belgium and the Netherlands you
AndersK
Like this? About 10 minutes in Design Spark Mechanical (freeware). Its a close fit so you might want to scale down a little or be prepared to sand it 😉 Design1.stl
maggiolo72
Hi, I have a BMG feeder ready to be assembled. Then I will do an extrusion test and will see. I have also several thing to put like silicon plug instead of the springs, new wheels, and some other
Posted Images
maggiolo72 6
I saw it but for what I know for ironing you need a special flat nozzle, or not ? Anny suggestion for settings ?
