Oh super, so printing with 0.15 layer will fix the problem.
Is possible to make the whole part in 0.2 layers and only the past layer 0.15 ?
Thank you and sorry next time I will attach a project file.
That's right, it doesn't seem to work so easily on your printer.
I had set this on an Ultimaker profile. Where he had cut off there before the adjustment also at the L something.
The Cura slicer tends to ignore everything it cannot print.
When I go to detail full deflection with a 0.25 nozzle, parts of the OFF are also missing from the ADF lettering.
To do that, I need to turn on Line Width.
I had no success with your printer profile.
Maybe someone else can help.
Wish good luck!
Vielen danke :). I will wait....
Hello @UlrichC-DE and @maggiolo72,
The new Cura version is called Arachne and the second beta is available in a post HERE. One of it's features is a variable line width and it handles narrow letters like those better than 4.12.1 (or earlier versions).
The first image below is your project file opened in Arachne Beta II. I did make some tweaks to some speed settings and also changed to normal support so take a close look at the settings. It is sliced with a .4 nozzle and .35 line width with Print Thin Walls enabled. If it works for you I believe the Cura team is looking for feedback over on Github. Actually, even if it doesn't work for you they would probably want the feedback.
One of the problems with the fine lettering on that model is that the STL is of a pretty low resolution. In the "Prepare" view in Cura take a look at the faceting of the holes. The fewer the number of facets, the lower the resolution of the file. That makes letters like O, G, D, etc. tougher to slice. The word "OFF" is so small that although it sliced OK it might not look to good in print.
This is with 4.12.1...
Edited by GregValiantThinking a bit more...
It might look nice doing a color change at 142 and 146. The letters are only 4 layers tall at .2 layer height. A little definition might be in order (although you would have a different color stripe through the rest of the print).
Oh yes 2 days... OMG
I had used the default settings. There is certainly still something possible.
You can try again with your project with the beta version itself.
@GregValiant needs only 1day
Many greetings
But the beta version is a new version itself or make some modification on the non beta cura version ? I ask before installing it....
You can run both in parallel, no problem.
It is a pretty much a totally new version. I think it is getting close to release.
I did cheat on some of the settings (there are a lot of outer walls so speed at 35 helped. Support Layer Height at .4 (2X layer height) so it only goes down every other layer. Still at 30 hours though.
Edited by GregValiantPrinted a small part for test with the Beta version, the letter are really ok, finally, but the quality of the top layer is not very nice, any guess or suggestion ?
AU20_HUD Panel Face Redesign - raised txt - IB.3mf
Edited by maggiolo72I did a test print of just the letters. I wasn't happy with how they came out. I opened the STL in MS 3D Builder, wiped out the text, and embossed new text. In the image below I've left the original and added the embossed "BRT". You can see that it would print much better as each letter has two walls. The word "OFF" doesn't want to fit and when it's too small it still doesn't want to slice.
Edited by GregValiantSo i made some tuning on the profile and with another piece looks better.
Any idea on how improve the top layer ?
It's hard to tell from pictures but areas of that print look under-extruded and other areas look good, and still others look over-extruded. Check your belts to make sure they twang like a bass guitar string. Also check the trolley wheels on the X and Y. There should be no wobble of the bed or print head carriage and you should just be able to turn any wheel with your fingers. Sometimes the hot end can get loose as well.
You can tell I'm thinking mechanical here. I think you have inconsistencies in the location of the nozzle (but I'm far away and don't see as well as I used to).
Yes it's better. Sometimes progress has to be measured in baby steps.
Are you ignoring the lower portion of the model in your testing or is that how thick it will be? I ask because when I tested I turned support off and sank the model into the build plate even though I was sure there would be problems because of that.
The lettering is looking much better and it's still only 1 nozzle width wide.
I still think it would look good with a color change for the lettering to give it better definition.
"The only way to get a finish like 12 coats of hand rubbed lacquer is to paint it with 12 coats of lacquer and hand rub it." - Me
Edited by GregValiantI print as is with 2 bottom layer and 3 top layers one skin.
I have no idea how do a color change, maybe it's too much for my poor U20 🙂
Hi there,
this is interesting, I've looked into this for some time and can see this is a panel made for an air craft "simulator" or maybe an "experimental" aircraft?
Those tiny letters should really need a 0.25 nozzle in order to print nicely.. But would not this letters be more easy to print if they are immersed in the panel?
If you're using black filament for the panel you can add white paint into the letters and make them more visible.
Also, you should try the last version of Cura (4.13 Beta), as it print this kind of object much better.
This HUD panel is much easier to print than the "Audio -select" panel. As Greg "says", there is a little tuning to do, but look much better now, great progress.
Way to go..
Good luck.
Thanks
Torgeir
Top Posters In This Topic
32
18
7
4
Popular Days
Dec 31
12
Jan 4
12
Dec 30
10
Dec 19
9
maggiolo72 32 posts
GregValiant 18 posts
gr5 7 posts
UlrichC-DE 4 posts
Popular Days
Dec 31 2021
Jan 4 2022
Dec 30 2021
Dec 19 2021
Popular Posts
geert_2
I haven't experimented with ironing yet, so I can't give advice on that. Concerning fighter jet cockpits: long ago, maybe 40-50 years, here in Belgium and the Netherlands you
AndersK
Like this? About 10 minutes in Design Spark Mechanical (freeware). Its a close fit so you might want to scale down a little or be prepared to sand it 😉 Design1.stl
maggiolo72
Hi, I have a BMG feeder ready to be assembled. Then I will do an extrusion test and will see. I have also several thing to put like silicon plug instead of the springs, new wheels, and some other
Posted Images
UlrichC-DE 122
Hello
the letters, especially the VO "L" are deeper than 0.2mm.
If you use a layer height of 0.15 it works.
For things like this, it's best to save the project.
File -> Save Project ..
Many greetings
