22 minutes ago, kupfeli said:Where did you find this?
CarloK is working at Ultimaker, so he has his sources 🙂 And if I am not completely wrong he is in the firmware team, so he probably wrote the code for it.
1
CarloK 208
This should be about it:
kupfeli 9
Awesome, thank you so much! Where did you find this?
Unfortunately that means I cant pause my printer using gcode 😞
A workaround I though of is moving the Z up and down with a very low feedrate that takes a while and then I have time to change filament.
I dont really understand why something like the filament change command is not supported. I do understand the Arduino/firmware situation, where you cant control the lcd from the gcode, but then again…printers like prusa also have kind of the same situation but there it works right?
I understand though that the 2+ Connect is geared towards the “just print my stuff without tinkering” people, so i understand the less dependencies the better.
