I was printing at 40mm/sec and slowed down to 10 to see if it was an issue with loose belts. But got the same results.
I measured across the face only and avoided the corner bulges. I also measured the upper layer only to avoid the bottom elephants foot.
Do you think I should loosen and realign all the axles to be safe? I suspect the problem is on the Y-axis because I noticed some layer shifts in some previous prints (Y direction only). Which is why I tightened the belts and noticed some slight play in the left Y axle.
Actually I just pushed on the printhead like you suggested. There is no play in the X axis. However, on the Y axis there is a fair bit of movement. The print head tilts up and down when I push it slightly. It looks to me like there is too much room between the center Y axle (where the print head is mounted) and the print head thru hole.
gr5 2,004
10mm/sec is crazy slow. Try at least 20mm/sec although that won't help. Also if you prefer dimensional accuracy over how nice the part looks then disable acceleration and jerk control in cura. You will get an increase in ringing which causes "ugly" ripples near sharp angle changes such as text or edges but will improve dimensional accuracy for example when using a caliper to measure things.
Are you measuring the whole cube or only the face because corners tend to bulge out. So I'm wondering if the Y issue is at the corner or across the face? Please answer this question. So many times people don't answer critical questions and then 5 days and 30 posts later I get the answer and it changes everything.
So I think the most likely issue is that your pulleys are wobbly - meaning the hole through one of the 11 pulleys (I think there are 11?) is not centered. This means the belt speeds up and slows down with each rotation. The problem could be with the pulley on the stepper motor or one of the 4 on the long belts. I could be wrong but if you stick with this hypothesis you can test it. If you print a cube that is exactly the same dimensions that is one pulley circumference then the problem should go away. By the way I'm thinking possibly the problem could be with the X axis and if you didn't have this issue then both axes would be 20.5. Or it could be on the Y axis.
Another possibility is play/backlash. Push on the nozzle in both directions for the X axis and again in the Y axis. Push with less force needed to actually move the steppers. Typically play will make the part smaller in the axis that has play. If you don't know what this word means, read about it on wikipedia. So you might have X axis play making that axis shorter. And some other effect is making both axes larger in equal amounts.
3DRocketry 1
Interesting, so if acceleration control and jerk control are disabled - the the accuracy should improve? What does this sat about Cura? If those controls are disabled, then the printer itself makes the decisions how to behave with regards to this those two controls.
Edited by 3DRocketryLink to post
