UMO print starts in mid air???
joergen
Posted (edited) · UMO print starts in mid air???
[UPDATE]
"prehistoric" also refers to the state of the grease along the lead screw and the z nut. it was all caked up and dried and made the z stepper loose steps. removing it, a deep clean and some new high-quality oil solved the problem.
Amazing to see a decade old UM still working great.
My (ancient) UM2 heated bed just gave up yesterday (separate topic), and I am trying to reactivate my (prehistoric) UMO, which i haven't used since I got the UM2 in 2015. A lot of the finessing and how to tweak gcode knowledge has been lost since then.
Problem: i need to get something printed today...
I got the GMO to home and heat up, and theoretically print again. home (0) is set to paper sheet thickness under the nozzle. I think the FW is a marlin flavor from 2014, but if there is a newer one, I can flash it (open to suggestions). I would prefer to not change the FW, because I am sure I tweaked a lot of parameters (dim, accel, pid etc) to a T for productions prints between 2011 and 2013)
something is wrong in the starting gcode, and the UMO prints mid air (about 15mm above the print bed). I used the original start gcode I found in Cura5, and also tried to change it, but no luck. would appreciate some pointers how to fix the start and end gcode, as well as what settings/flavors i should change in cura5 (i.e. relative or absolute E? etc). it appears the line "G1 Z0 Y50 F9000 ;move the bed and the head" doesn't move the bed back to 0. Help please
Quote
;start g-code
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F9000 ;move the platform down 15mm
G1 F200 E6 ;extrude 6 mm of feed stock
G92 E0 ;zero the extruded length again
;Put printing message on LCD screen
M117 Printing...
Quote
;end g-code
M104 S0 ;extruder heater off
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
Quote
;print starts here
G92 E0
G92 E0
G1 F1500 E-6.5
;LAYER_COUNT:298
;LAYER:0
M107
G0 F3600 X44.098 Y38.408 Z0.3
G0 X41.786 Y41.69
;TYPE:SKIRT
G1 F1500 E0
G1 F3000 X42.09 Y40.816 E0.02611
Edited by joergen
updated
    Posted · UMO print starts in mid air???
    4 hours ago, joergen said:
    [UPDATE]
    Always share some amazing and informative information with us, Thank you for sharing the detail.
    The code looks fine.  I think your Z speed or your Z jerk or your Z acceleration is faulty.  Or too much friction on the Z.  Try moving the Z up and down by 10mm movements to see how it does.  You can do this from the menu system.
    yes, a sticky/dirty z axis was the problem
    • gr5 locked this topic
    Guest
    This topic is now closed to further replies.
