Thank you very much for your investigation.
I am now quite confident that there is an issue when printing only with right core (except the skirt at the beginning)
At the end, it hits the front, but mainly it travels from right to left with the plate way to high.
My guess is that the new update that enables faster ends has an issue. The cores are travalling in the middle of the print if the build is at top.
When there is purge on left core, the build lower just before going to purge right core. But this is the move when you really printed with both cores.
I force all my current prints to use both to prevent this issue to happen and further potentially damage the printer.
I came in the forum looking for a displaced build plate exactly like the first picture. I was surprised it was on the other side. If they fixed a bug on left to right, maybe there is still one from right to left.
II made more than 150 prints before this firmware. It's second time I report an issue using two cores (on Cura last time) and there was a bug last time and it has been fixed.
I did gave you the rights to the video, sorry for the delay.
And maybe I am doing wrong or that my machine is broken 😕
Cheers.
Fernando_alp 0
We seem to have run into this exact issue today, not sure if it will relate but here's our story:
