Question in the Cura settings_printing a network of open mesh file.
alan_k
Posted (edited) · Question in the Cura settings_printing a network of open mesh file.
Hi all,
I need to print just one layer of this kind of fibrous network in 3d printer. (1st image)
I was trying to slice it using cura, but I cn't seem to find a setting where they talk about opened mesh.
is there any settings that you guys suggest in order to print something like this?
or do I need to change the mesh file to something else?
Thanks in advance!
Edited by alan_k
    Posted · Question in the Cura settings_printing a network of open mesh file.
    It is rather hard to see what you want to do from these images, but perhaps you are interested in this plugin:
    https://github.com/Ghostkeeper/SVGToolpathReader
    It does not yet seem to have a release for Cura 5, so you would have to use Cura 4.13 to use it.
    I want to make a geometry that looks like the 3rd image with a single layer if this makes sense.
    If that geometry is flat, then exporting it as an SVG and using the SVGToolpathReader plugin (in Cura 4.13) will go what you want.
