14 minutes ago, Smithy said:
So we can exclude the print core and other things, because after your change of the feeder you have the problem on the other printer with a different print core, right?
yes this is excatly what is happening.
Differentkind of materials, PLA,PP, PPCF, PA6CF, PA6, ABS
So yes also abrasive Materials.
The Problem is that the feeder is working for 70% of the printjob and than it starts to grind the filament. If I recognize it early enought and help the feeder to get over the spot he ground into, the printer will keep on printing normally.
Smithy 1,146
Hi
I mean the feeder gear could be worn out and if you already have cleaned to feeder there are not much more possibilities left. What about the tension of the feeder, is the marker in the middle position?
Which materials are you printing? Do you print also abrasive materials with the printer?
