I would say even less.... i tried it with even 90.... still leaves a bit of a string... lets say 80 possible....
just tried the RC6 multiple printer's function. it is good, but seems the different machine share the same
start/end.gcode. Is it a bug or specific start/end.gcode for each machine is not support yet?
It should have different start/end code for each machine. But looks like I managed to bug that... I'll fix it soon.
I really wanna try your update but Cura keeps crashing when i click print from usb. What to do ? i deleted all old files of cura
But in the RC7 on MacOS, already fixed it.
i used RC7 but still doesn't work :/
there is a bug with the layer preview when "spiralize" is selected. The topmost layers look weird when scrolling through layers up and down.
RC 7 fails to slice an STL file which worked fine in prior 14.01 releases. Shows 0 time and trashes the layer view. File loads and looks fine in all other views. It's a copyright graphic file which I'm developing so I don't want to upload it but can send it privately if that would help.
Thanks for all your hard work.
Bruce
Bruce
You can email it to d.braam@ultimaker.com I'll keep it confidential.
"bug in RC7, fixed already for next release"
Ahh okay super.
It slices fine, but due to changes in the layer view it looks a bit messy for such a small object.
No, for some reason it's seeing COM3 as an USB serial port, which I'm not sure if it should in your case.
Cura reads the registry keys from "HARDWARE\\DEVICEMAP\\SERIALCOMM", and checks if there is an USBSER in there. It has done so for quite a while already, so I'm confused why it would show up COM3 all of a sudden if it did not before.
I've just overwritten machineCom.py with the present git version and now it works as it should... let's see for how long...
I see that 14.03 is released on 17 march. So it is not a RC anymore.
It was not clear whether for XP a separate version was available, and the 14.03 version and the 14.03-for-XP had the same size. Anyway, the version indicated as 'for XP' was downloaded and installed.
Still the layer view sounds 'pling' and the program does not respond anymore.
No message is shown, so this is all I can report.
Former 'pling' results for 14.02 were from a 'real' machine.
Installed 14.03 on a fresh VM with XPSP3, same 'pling' result. Here, OpenGL 1.1.0 was found.
Installed 14.03 on a fresh VM with W7, and layer view was OK. Here, OpenGL 2.1 was found.
The stl object was put 'swinging' to the platform, The layer view was 'building' up from the top, and I could watch the layers at all heights.
So is the problem caused by different OpenGL or by Windows version?
Most likely the OpenGL or VM combination.
Problem solved in 14.05RC02 (same XP machine...) ! Thanks!
39
28
17
14
Popular Days
Feb 19
27
Feb 21
21
Feb 24
14
Feb 20
13
Daid 39 posts
Dim3nsioneer 28 posts
drayson 17 posts
maartenw 14 posts
Popular Days
Feb 19 2014
Feb 21 2014
Feb 24 2014
Feb 20 2014
Nicolinux 288
Daid,
this is not a bug, but potentially annyoing for everyone so it might be a worthwhile UM2 firmware improvement. I am posting it here because it is related to Cura and because I hope it will make it into the very next release.
Filament temperature is too high while changing material.
This leads to strands of filament stuck inside the bowden tube or strands that end with a big blob that won't pass the knurled bolt inside the extruder. Every second filament change I have to fish it out with a toothpick.
Not sure which temperature would be best for PLA, but lower than 220° in any case. Maybe 190°?
