6 hours ago, gr5 said:Or you can replace some of the Z parts - particularly the Z nut followed by z bearings and the 2 z rods and finally the z screw.
I already replaced the two Z rods, bearings, lead screw and nut. They should be good...
I tried your brick Idea and added a 2kg weight to the back of the bed. Made no noticeable difference.
Do you rule out extrusion or other mechanichal issues?
Left with 2kg weight.
Edited by elnadav12spelling
GregValiant 1,330
I read that article. It made sense to me so I picked up one of these Mosfet boards and printed a box for it. It sits in back of the printer. It has an LED and I can see when the bed turns on. There was a slight difference in prints. Mostly I'm glad to get that current flow off the mainboard. Wiring was easy. The wires from the mainboard to the bed get cut. The mainboard feed becomes the signal line for the Mosfet. The other terminals are power in from the power supply and then the old wires are power out to the bed.
In regards to your print it does look like a mechanical issue. The extrusions on the side of the pilot house look to be wobbling. You have some ringing around the hawser hole in the bow as well.
The line on the hull where the deck meets the hull is a well known phenomenon. I think doctoral thesis have been written about it.
Go back over the printer for the umpteenth time and see if something is loose or bouncing or vibrating. All vibrations can end up in a print.
I'm not an UltiMaker guy though. Maybe @gr5 has a take on this.
gr5 2,210
This horizontal banding is usually caused by Z axis issues.
So the z screw moves the bed down a tiny amount between each layer so you are relying on the weight of the bed to make it go down the same amount. But if, for example, the z screw is dirty some layers it doesn't go quite all the way down (imagine some dirty grease that doesn't compress as much) and then on the next layer it might go extra far down because there's less grease a little farther around the screw.
And if the bed goes down less than it should then it over extrudes and the layer sticks out a bit.
And if the bed then on a later layer goes down *more* than it should then you get an underextruded layer.
Am I making sense.
One experiment is to add some heavy bricks to the rear of the test bed to see if that helps.
Or you can clean the Z screw.
Personally I would clean the z screw - near the top - the part of the screw that is in the nut when printing benchy so like the top 3 inches maybe. Clean with some WD-40 and a toothbrush or just a paper napkin and your fingernail. Keep in mind that the z screw is a triple helix so if you get your fingernail in the groove and spin it around and around you only get one of the 3 grooves.
You probably don't need to add any grease. Ultimaker says one pea sized drop of grease is enough for the entire z screw.
If that doesn't help try my brick idea.
