- Solution
Thanks! I was able to pry it apart pretty easily with a small flat screw driver. Slipping the screw driver between the two halves, I was able to see the legs of the internal tabs. Then, I pressed in slightly on the legs with the screw driver while pulling it apart.
Swapping to the old bushing sleeve and reassembling was pretty easy. The belt and spring stayed in position.
I attached pictures of the open one, and pictures of the faulty bushing. It has gouges and abrasions on both ends, and it skewed the shape of the opening.
Should be back up and running.
1
gr5 2,094
I'm pretty sure you have to apply a scary amount of force but I'm pretty sure they pop apart. I think there is like a cat's paw from each side that grabs the other and that could break in theory but in practice I think they pop apart. if you aren't in a rush let's ask @IRobertI. I suspect he's taken many apart. These are certainly a pain to get back together.
I also think they are identical to the black ones but a different type of plastic that is less likely to crack (they have had cracking issues in the area where they clip to the rods). Same mold. I think. I forget if the white ones or the black ones are better. I think black are better on S5. (and the opposite with the UM3: black ones crack more, white ones better, life is crazy).
It looks like you are in USA so you should contact support@fbrc8.com with an email (and include your serial number! That saves time as they will ask anyway). They are experts on the S5 partly because they built all the ones sold in USA and partly because they don't hire idiots.
