You should make sure your wall thickness is thick enough for two passes - so 1.3mm would be the minimum although with the threads being at an angle from vertical the cad software might be off by .01mm or so. So I would consider maybe 2mm as a minimum wall thickness for the threads.
IRobertI 516
"The wall thickness inside the thread is good"
What IS the actual wall thickness?
I'm guessing it's simply that the wall is so thin that cura has trouble fitting your 0.65mm nozzle in there.
