I also cannot select multiple files in the Open File dialog box, whereas this worked fine before 5.4.0. I'm using Windows 10. (Being able to bring in multiple files at once is hugely useful and I didn't even realize how much I actually use this feature until I found it not working.)
I use Cura 5.4 under Linux and I can`t set the temperature of the printing plate and the temperature of the printing plate for the first layer in my printer settings under material, it is always at 70°
Printer is the Elegoo Neptune 3 Pro
Does anyone have any tips how to set the pressure plate temperature?
Edited by Henny30Someone cut my forest down...
I been using Cure 5.3.1 for the last month now and the trees have been great. (on my Elegoo Neptune 3 Pro) I installed the new 5.4 version and now the forest of trees has been clear cut....extremely simple overhangs are not showing any support and the tool is expecting that parts at a 85degree angle can just float....magically...
I'm trying to figure out which setting is the key one that tell the slicer to add a tree support but i can't seem to figure out what is wrong. Normally the Support Overhang Angle was the KEY one but even items highlighted in red before slice go without a support after slice...
Edited by Sertain
- 1
@fc2kool I recognize the report about selecting multiple files. It's also been reported here https://github.com/Ultimaker/Cura/issues/15879, the team is aware of the issue, it's probably caused by upgrading the PyQT to solve some other issues, and introduced some speed improvements. Hopefully we can resolve it in the next release.
@Henny30 Getting a setting to show up by default is actually quite complicated. You can read more about it here If you don't want to change it manually each time you might need to create a profile where this shows up.
@Sertain Wow, that should be supported. Could it have to do something with your Minimum Support Area? If that's not it, Do you have a project file for us? It contains the printer and settings we need for troubleshooting. To save a project file go to File -> Save project.
Hi
Not sure what I done wrong, I sliced same dragon pencil cup stl on both 5.3.1 and 5.4.0, the result were not what I expected.
I would like to pointed out the settings on both versions were the same. The expected completion time given by 5.4.0 was 1 day 2 hors and 18min, see attached pic 5.4.0.gif, and the expect completion time given by 5.3.1 was only 17hrs and 5mins. Most important, 5.3.1 seems use less support compared with 5.4.0, see attached pin 5.3.1.gif
Hey @newbiz,
Welcome to the UltiMaker Community 🎉
Looking at your screenshots, 5.3.1 does have less support with the settings you selected. But I also believe that your printjob will fail with these supports if you actually try to print it. I expect that for this before and after picture they had to increase the support overhang angle to even get the printjob to print. There are also reports like these that it takes significant longer to remove the supports with the old tree supports.
Does this help?
HI MariMake
Thanks for your reply, you properly right, but I do not understand, why i got that result from 4.3.1. the same profile was used on both 5.3.1 and 5.4.0, I did check with preview on 4.3.1, I did not actually print it, as it takes too long to print, beside those have support, the reset should be ok without support, overhang with good part cooling, I possible wrong on this, but I will try to print it after scale it down
BTW The support parameters I have on the profile
support overhang angle 60
support branch angle 60
support density 6
Good day to all,
I can report the same thing happening as Sertain, when I use the default option for Minimum Support Area of 3mm² (Profile is for Elegoo Neptune 3 Pro). If turned to 0mm² the supports return. (see images)
Maybe this an error affecting profiles?
However, I did not test the supported print yet.
I posted earlier than I wanted.
Hey @NotABot,
Your report reminds me of https://github.com/Ultimaker/Cura/issues/15886
Can you change the Support Distance Priority to Z Overrides X/Y?
Does that resolve your issue?
Thank you for answering @MariMakes. The Support Distance Priority was already set on Z overrides X/Y, but changing it to X/Y overrides Z seems to fix this behaviour, the supports are then generated again, with the limitations described in the issue.
Edited by NotABotGregValiant 1,287
One man's opinion.
I do believe I gave 5.4.0 a much higher rating than it deserves. There are way too many models that it is not capable of slicing. Updated Aug 4.
Things like this lead to opinions like that.
This falls under the heading of "C'mon Man!".
https://github.com/Ultimaker/Cura/issues/14764
Edited by GregValiant
- 1
Just wanted to thank the folks that made the brim that nicely removable! Exceeded my expectations!
- 1
Hi, on Cura 5.4 how can I restore layer view like Cura 5.3?
How restore "Select face to align to the build plate"?
Why they change stuffs without let the user choose during installation?
Why they don't change the very ugly GUI interface where you have to scroll a lot of setting, where they can separate the dropdown menu on the useless first empty row (View type - Color scheme) and add personalized buttons to fast switch ex: Support ON/OFF, Brim ON/OFF, etc.
- 3
Not a issue on the release, but a on the hardware. The graphics card is not compatible in the 5.4 case . Have you change your hardware ? or change the option of graphic compatibility ?
Edited by Cuq21 hours ago, Travis90x said:Hi, on Cura 5.4 how can I restore layer view like Cura 5.3?
It looks like Cura 5.4 is having an issue getting proper OpenGL 4.1 support from your GPU. Either that, or you may have (inadvertently) have enabled the option to "Force layer view compatibility mode" in the General preferences in Cura. This could also have been changed by loading a project file from someone else who has that option enabled.
21 hours ago, Travis90x said:Why they don't change the very ugly GUI interface where you have to scroll a lot of setting,
You might like the Tabbed Settings plugin available in the Marketplace:
- 3
With the beta I got a LOT of slicing errors that would usually be fixed by just rotating the model on the buildplate. (around the z-axis for you z-up heathens) That was really annoying BUT I was running into a lot of times where the beta would just stop slicing. No error, no rude noises, just stop.
So far I haven't run into any of that with this release. I'll give it a provisional Great Job!!! 🙂
Different line-width in outmost 2 walls.
I've got different line-width in the outmost 2 walls in the first layer of my model. At these sections of the circle, the nozzle drives faster than in the other sections. See enclosed screenshot and project.
GregValiant 1,287
Turn off the Bridge settings. They aren't needed for that model anyway.
But the bridge settings should not be affecting the print like that either.
- 1
On 7/30/2023 at 6:02 PM, GregValiant said:Turn off the Bridge settings. They aren't needed for that model anyway.
Thank you. That's the point. Disabling the Bridge settings provides smooth walls in the 2nd layer. With Bridge settings enabled, it appeared only in the 2nd layer.
Couple of things (bugs) that is wrong or need to be fixed / re-added with Cura 5.4.
- Unable to select and open more then one file. - This is an extremely useful option that is available in the older versions. I use this daily when the model has multiple parts that I can print all at the same time.
Lay flat option located in the rotate tab. (bug?)
- It lays the part flat correctly. However it does not leave the part in same place after laying the object flat. It rotates it slightly and will place it randomly anywhere on the print bed graphic.
Can sometimes have minor conflicts with the custom cylindrical support extension.
- After setting a custom support from the above mentioned extension, Cura will give error that it can not slice the model.
- Does not always arrange larger models correctly. Sometimes it will push one outside of the printing area instead of aligning them correctly into the printing area even though they will fit.
fc2kool 2
For version 5.4.0 and beta i cant select multiple files and needs to be fixed asap otherwise i will be forced to reinstall and use UltiMaker Cura 5.3.1 cause im able to select multiple files with no issues!
Forgot to metion im using Windows 10 pro 64 bit.
Edited by fc2koolWindows Version
Dadkitess 19
Gosh the PET-CF is damn expensive oO
