It could be the PCB or a bad front fan. Check the front fan wire and make sure it is not damaged.
Unplug the front fan from the back of the print head and run the test three more times. You need a new fan if the noise levels return to normal (under 8). If they stay high, you will likely need a new printhead PCB.
Torgeir 243
Hi @Pena
The noise level test are made to insure that "noise" is not present much, as it can destroy the calibration of the bed.
When using a capacitive sensing system like this, nearby noise will cause problem if it exist!
This might be nearby WiFi or cellphone etc., but may also include any EMI created by the printer itself.
We've seen that the little cooling fan inside the front cover sometimes been the reason for such noise from the printer itself.
As your readings fluctuate quite a bit, it might be due to much noise from this cooling fan.
I've never seen any "values" that's become a limit causing a warning in this matter.
Maybe caused by every individual often have its own level that's change when parts are replaced.
Often an experience in the industries in general.
Thanks
Torgeir
tomnagel 126
I suspect your print head control pcb is broken, such noise values are really really bad. Please contact support or your reseller.
