I wonder why the default setting is 0.6 mm top/bottom thickness... I never ever got good results with that..
My preference is using 23% infill and 1mm or even more top/bottom thickness. That gives you a pretty strong part, but it's not the best choice for saving material..
ian 32
the problem is.. when you use a normal infill like 20 percent... and a thin top bottom layer... the layer lieing above the opening between the infill will pop up a little. if the layer is set to thin.. the pop will actually break the top of the surface and then you have bumps and openings... not good.
Im not 100% sure why the bubble happens.. but maybe because of trapped heat being trapped and pushing up the new thin layers or... when the material is printing, it cools and bends upwards... and because there is no material under it to hold it down.. it bobs up like a baloon... probably that !
best solution is to increase your top and bottom layer height in Cura !
Something like 1.2... or 1.5 should be good... If you increase infill that wont really help so much.
Hope that helps.
Ian :-)
