The type of 3d printer that melts plastic through a nozzle doesn't do overhangs very well as you just learned. You can use support structures but they leave a rough surface behind. That's why you rarely see 3d printed balls. You could consider 3d printing a mold that comes apart in 2 halves and use 2 part silicone mix. That comes with it's own learning curve (bubble issues, how to make proper fill tubes, mold release, shore hardness) but you can get great results.
Or if you have a dual material printer like an Ultimaker S3/S5/S7 you can use a dissolvable support material or a "breakaway" support material in the second nozzle that will leave a much nicer surface finish when you remove the support.
- 1
GregValiant 1,256
@Slashee_the_Cow has been printing a lot of TPU. Maybe she has some thoughts on this.
If it was me, I'd print two halves and glue them together. That would get rid of the entire "horrible support surface" problem.
Super-glue works well with PLA/PETG but I don't know about TPU. Some sort of bonding agent should work though.
