Hi @Xhoax,
as you bought a second printer of same brand, using your "same" filament printing fine at another place..
This is kind of weird, -but suggesting you're living on the northern hemisphere -a little north(?). Six weeks ago the temperatures "around" riced quite fast.
What kind of environment are your printer used (temperature)?
As everything else is sorted out, -this is my best guess..
Slashee_the_Cow 450
I suggest you contact UltiMaker support to see if they can help you with this problem.
Depending on what filament you are using, it's possible that differences in the ambient temperature or humidity could be causing underextrusion.
Another thing which could potentially be different is how the filament is being fed into the printer. Unfortunately I don't know much about UltiMaker hardware so I can't suggest anything specific.
