So multiples of 0.001875mm ?
I don't know if this is still accurate but this information says:
https://groups.google.com/forum/#!topic/ultimaker/rDneN2H0ixQ
"On Saturday, February 23, 2013 10:24:05 PM UTC-5, [email protected] wrote:
2. The lead of screw is 3mm, but I don't think this is a good choice. When the screw makes one rotation of 360°, the Z-plate rises up 3mm. The step angle of stepping motor is 1.8°, this means 0.015mm is the minimum step distance. So it is hard to reach the common layer height such as 0.1mm, 0.2mm. Perhaps, 2mm, 4mm or 5mm for lead of screw is better.
The Z screw is pretty much the element with the highest resolution in the whole system, about 7x better than the XY. The Z stepper is driven with 1/8 steps, not with 1/1 steps as you mentioned above, so it has 200*8 steps / 3mm = 533.333 steps/mm or 0.001875mm per step (8 times better than what you mentioned above)... so, why is the 3mm acme screw a bad idea? and how would a 2mm, or a 4mm, or a 5mm lead screw improve anything?
codemaven 0
I've wondered this as well myself, but have never bothered to figure it out other Mathematically. The NetFabb defaults for the Ultimaker use a layer hight of 0.08 for the 'Ultra' quality and multiples thereof for lower resolution prints... And I've played around with this quite a bit trying all sorts of odd and even layer heights but I have always found the best results to be divisible by 0.08 on my machine. I get far better results at 0.08 than I do at 0.06, and similarly I get nicer results at 0.160 than I do at 0.1.
Regards,
Troy.
