@dimensioneer: Thanks for your help. Mininum layer time was 5s. I've pushed it to 7s. I have also installed Flowthermostat which looks great - good tip, thanks.
Could you please clarify what is the cool head lift feature and where I can find it?
Thanks a lot!!!
Dim3nsioneer 551
First, set the minimum layer time to 5-7s in order to give the deposited material enough time to cool.
The minimum speed should not be below 10mm/s.
Furthermore you can try the cool head lift feature.
Personally, I use either the Flowthermostat plugin or the TweakAtZ on the layer where the print speed drops below 25-30mm/s.
