328 is really high. Is the UM able to handle that much heat?
It's a typo. Should be 238°C. You may check the taulman website...
So spend the $5 or 5 euros and get a piece of glass. Clamp it down with paper clip binders. heat it to 40C with a hairdryer and try it out as suggested.
I print T-Glase at 240C on a heated bed at 50C with blue tape... It prints fairly well, but it's best if you print very slow with large (~0.2mm) layers.
Cheers,
Troy.
Thanks, I ended up at 238 and 50 as suggested on blue tape and finally got things working well. I did slow my print speed down as well.
Sorry for the alarming 338 degrees typo.
anon4321 16
There is temp recommendations from taulman. http://taulman3d.com/t-glase-features.html but they imply that a heated bed is needed.
