Have you allowed the bed to cool down? If you try to remove it while hot it can be fairly difficult.
If it is cool, try to use something thin and sharp (like a putty knife for example) and get underneath the print. Then gently pry it upwards and it should come off without too much problem.
Thanks for the tip, it was about 1hr ago. I will wait a little longer and go give a try.
I laid down a think layer of Glue like i was instructed, so I didn't place it directly on the glass.
IRobertI 497
