Dear gr5.
Thanks for your answer. But I'm sure you will understand that I'm waiting for an answer from Ultimaker staff.
Thanks for your tips too. But seriously, I wouldn't have to open a machine which never works properly and just come back from technical center ! Do you have to open your gearbox to fix it when you buy a new car ? I guess no.
About the slippering. I work at 230°C with PLA from Ultimaker, 70 mm/s, 0.2 mm high. And it didn't work ! Please, as I said before I use some 3d printers since a while. It's why I can know if something goes wrong or not...
Do you think it's normal to have tu push the filament by hand to have a good printing quality with these parameters ? I dont' think so.
Here his the result when I don't help to push the filament by hand :
The worst thing is that we perfectly hear the "click" noise during slippering and seeing that the gear from filament feeder stopped. But even if I sent some videos to the technical center, they sent me back the machine witjpout any fix on this. Seriously I think they didn't test it before sent it back to me.
Ok, let's try to forget about my machine which didn't work anymore...
- 300 mm/s from catalog, can't go up to 70 mm/s
- 0.02 mm layer hight on catalog, can't work if I'm less to 0.1 mm with 500 mm/s (due to slippering). Please, not that you can't choose less than 0.025 [mm] in Cura even the UM2 datasheet said 0.02 [mm]
- 230 mm max built zone on X axis ? So, try to put a piece which is more than 220 mm on Cura... it didn't work
- I never seen anything to upgrade to 2 printhead, even it was on of the advertising argument on the website before.
Oh, I forget that I'm still waiting for filaments spool that I ordered in January and about the heavy scratches on the buit plate of my UM2 when I received it.
They could have good product. But I think they will kill their business by unfulfiied promises, a poor customer services and the worst consideration for customers that I have never seen before.
And today I'm really thinking that my machine would never work well and that Ultimaker was the worst choise to do.
Seriously, how could a machine not being fix after getting back to technical center... and come back with a new issue ? It's unbelievable.
gr5 2,333
Temp sensor error occurs if there is something wrong with the wiring to the temp sensor. First, take the larger cover off the bottom (two screws - very easy to do) and look at the "temp1" connector (appears to be brown/red in the below picture). Make sure it isn't loose. You might need a complete new temp sensor cable.
As far as grinding/slipping - this is more complicated and might be normal. What material, temp, speed (70mm/sec) and layer height are you printing at? For example if the answer is PLA, 200, 70,.2 then that would explain the problem as you can't print PLA that cold and fast. But there might be some defect - please answer the above question first.
