Sounds extremely complicated.
Better would be to model the pattern in CAD on the "inside" of the lamp housing. That would be very cool.
That reminds me of this print I did:
That's pretty awesome
Thanks. Cura has this feature built in - you just load a jpeg file instead of a STL file.
And I guess the routine for the jpg-feature could be used for the generation of a custom infill pattern...
Sure. If it is to go on a flat rectangular surface. But someone mentioned a lamp shade. A bit more complicated. And the next person will want to put it on a iphone case with holes for camera and buttons. And then the next person...
It gets very complicated. This is really a feature for CAD software and some programs already do this.
gr5, do you know any opensource cad program abble to do that? Even with a .stl?
maybe Blender I guess
well i didn't know that.
Saves me messing with the lithopane software
Only disadvantage with the JPG it doesn't recognize transparent layers. Always a rectangle of the size yo entered a JPG.
Maybe we'll need to check the underlaying code to enable that part ;-)
Greetz Xiao Shi Zi.
P.S. will check the litho ;-)
I've heard people discuss this feature but I don't remember what cad it was. I think it was blender but I'm not positive. I do remember that there were 2 almost identical sounding features where one made it *look* like the surface had texture and the other actually changed the texture in the STL.
bitmap bumps
or
bitmap surface
or
bitmap texture
something like that?
Actually I know a package that does this but doesn't creat STL files: kerkythea. For example you can create a flat wall and add a photo of bricks - but even better you can add a bitmap file that says where the bricks stick out and where the mortar lines are and it 3 dimensionally modifies the wall so that lighting and shadows look perfect from any angle. In kerkythea you can say for example if black is "in" or "out" on the surface and by how much distance.
But kerkythea doesn't then convert this to STL - it only uses it internally for it's lighting engine.
thx.
Will investigate whats best for this infill thing.
Keep in touch.
Will test that out in a few weeks.
Openscad also has a simular bitmap feature.
Indeed, it reminds me this
http://blog.cubehero.com/2013/11/11/how-to-generate-extruded-3d-model-from-images-in-openscad/
tutorial. Indeed a nice Opensource Possibility to try. Thx Zoev89.
Will check to use it in Freecad as there's an openscad module to and it's a gui instead of typing a lot.
Greetz Xiao Shi Zi.
Dim3nsioneer 559
I kind of like that idea, actually...
It would be a good way to satisfy everyone's wishes about the infill pattern.
