Hi, it happened well after 5mm, one was spinning full speed, the other was not moving, I pushed it and it started moving, seems odd
Sounds to me like a faulty bearing. I think the only thing you can do is replace the fan.
Sometimes a tiny bit of debris can stop small fans from spinning up, I get his quite often with my RC models. It might be worth checking to see if there is a chunk of fluff restricting it slightly.
Thanks for the replies, I tested the fans with the fan control on the menu and they all seemed to work ok, from 0% up to 100%, I turned the dial very slowly and they both started spinning together and increased in speed, I will keep an eye on it with my next print.
I have the same issue, also with the right fan. UM promised me about a month ago they would send me a replacement for it. Never heard of it again. Sigh
Are both fans controlled independently? or both fans are actually connected to one PWM driver?
Still have a fan problem, I am printing something as I write this, one fan started spinning very slowly and the other one was not moving, I waited for a few mins, still not spinning, so I pushed it around with my finger and then it started spinning on its own, does this sound like a faulty fan then?
When I test when with the fan speed control on the menu they seem ok
If you push the head around when you control them from the menu, does that make a difference? I was thinking that there might a bad connection and/or wire somewhere that is making intermittent contact? Just a random thought.
IRobertI 502
Is this just at the beginning of the print when the fans are spinning slowly, or even when they're supposed to go full speed (after 5mm by default)?
