The reason I am asking is that I printed some Lego compatible blocks. When simply using the default Lego dimensions it does seem to work, but the block seems a little smaller and the fit is not optimal. The difference is small though, so I was wondering whether this is due to shrink or other inaccuracies.
Most prints tend to end up slightly smaller than intended, but despite attempting to make sense of it with calibration objects designed for that purpose it seems hard to get a common denominator or simple factor. I am sure I am not the first to meddle with this though.
I have had my share of warping shrink too, but I am slowly but surely getting a grip on that. In my mind those are two somewhat different matters
valcrow 144
It often depends on the shape of your object. Sharp corners tend to shrink and pull off the bed more (as in, it shrinks not just inwards slightly, but upwards) You can counter this by making the corners rounded, or adding a brim which helps it stick on the bed a bit better.
Large solid blocks of objects tend to shrink a bit more. Cutting shapes out of your object help the shrinkage, for larger objects I like to cut pyrimids into the base of the object (so long as that surface is not seen) to even out the stresses.
But more often than not, PLA has nardly noticable shrinkage unless you're printing big things. I just printed a 6" cubed object and the corners pulled up maybe half a mm. But it still printed fine.
I often don't really need to consider shrinkage in the design unless the parts have to glue together.
