Dim3nsioneer 553
@Zews: You said it. The Ultimaker antennae print fine because they are TWO.
I recommend to decrease the temperature as far as possible (190°C for 10mm/s) and set the minimum layer time to 7s. Then print two (or even more) of the object at the same time. Alternatively you may try the cool head lift feature.
xyzlord 0
my guess is that you are extruding to much try reducing the fill density to 40-50%.
