Hello,
thanks for your reply. I forgot to say that my print is rotated at 45° on the bed. So could this be the failure? If i don't rotate my print, everything works still fine. The wall ist straight. There are no curves.
So i think this is a cura slicing problem?
Dim3nsioneer 559
Hi Johnson
Welcome to the Ultimaker forum!
The wall thickness in Cura should always by a multiple of the nozzle size. So setting the nozzle size to 0.4mm and the wall thickness to 2.0mm should indeed result in two two-shell walls connected with some infill. And it doesn't?
Is the wall straight or do you have some curvature?
Maybe you could post a snapshot of the Cura layer view?
