I run a um original with no heated bed and glass plates - I have blue tape under the glass plate and a small 3mm spacer to fool the end switch when I have glass on. I use dilute PVA - I probably print for about amonth or so before I wash and re-coat the beds.
That is for PLA - for XT I use the tape and get no warping, but I want XT to be as easy as PLA - so I am going to install the upgrade and see what happens (I have 2 UM classics so if the heated bed is no good for XT I will still have the cold glass/blue tape set up)
While I am always impressed at the accuracy - I am curious to see if the z-stage improvements will be worth it without the heated bed.
So I love having both glass and blue tape available - if I don't like the HB then I can just use the same glass sheets I have now - it has just dawned on me that I could put blue tape on the underside and then have a removable blue tape plate
But I really like having an OEM heatbed option.
James
IRobertI 513
Even if you don't use the heated bed I'd still go for the upgrade as the z-stage of the new printer is much more stable. Level it once (with the easier to use three point system) and you don't really have to re-level unless you're very violent with it.
Maybe buy another sheet of glass (cheap at your local glass supplier) and just switch out the glass between prints?
The glue isn't messy IMHO. IF you need to re-glue between prints you can just put a bit more on and spread it around with a damp cloth/sponge.
Personally I use ordinary "white wood glue" diluted with water and then spread on the bed. I've re-coated my bed once in the last 3 months or so (granted i don't print a ton).
Not sure what you mean by shrinking parts. If anything a heated bed prevents shrinking (that's sorta the whole idea behind a heated bed).
