DidierKlein 730
Hi and welcome to the community
When the printer finishes a print, the fan behind the head will continue blowing and the leds will stay on (unless you changed the settings). I don't think much damage can happen to the printer while being idle, but if you need it to shut down after the print, one easy way to do this is to set a timer power socket and be sure to shut it down after the print is finished
donmilne 2
Actually, I don't think you need to be quite so paranoid about breaking your printer. Yes, it's an expensive object, but if it you look at it it is mostly just standard bright steel rods, stepper motors, threaded rods, tubing etc. All easily replaceable if they break. The only specialised parts are the controller and bits in the hot end - and I'm sure you can get spare parts of those from UM.
In regards to your question, I don't know of any internal feature: the power supply is probably quite basic. However you can easily buy a timer power socket.
