Hi Dim3nsioneer,
Thank you for you prompt response. So beside the heated bed missing on the go the only technical difference to the current UM2 is the build size.
I did not expect to get an answer on my UM3 question but no harm in asking :-)
Thank you again. :-)
Dim3nsioneer 558
Hi Kroete
Welcome to the UM forum.
The GO has no heated bed.
Due to the CE conformity there will most probably no upgrade for any printer of the UM2 family.
And only UM knows (maybe) the answer to your last question. But they wont tell.
