cloakfiend 995
Thanks cloak fiend for posting all your research into this - it's really interesting to see what you are doing with the Acetone - I tried it ages ago and thought that it didn't do anything apart from bleaching the PLA - you have been very observant - I'm going to have another go with some old prints in different PLA colours.
Remember it works only with 0.06 colorfabb PLA, or 0.1 (depending on the model) with UM PLA but by all means have a go. It always depends on the material and also sometimes in the way the model is printed. You will always get subtle banding, but I recommend sanding after the primer coat to remove them as sanding before doesn't really completely get rid of them for some reason, and the acetone just brings them right back....dont be afraid of a little sanding! but wear a mask when doing it as the dust is real fine. So basically a touch of sanding before and a touch after. you also dont need so much prime, even spot coating is fine.
318
31
28
28
Popular Days
Dec 18
24
Dec 9
13
Nov 17
11
Jan 6
9
cloakfiend 318 posts
geert_2 31 posts
SandervG 28 posts
KevinMakes 28 posts
Popular Days
Dec 18 2015
Dec 9 2015
Nov 17 2017
Jan 6 2016
Popular Posts
cloakfiend
ACETONE AND COLORFABB RED TR FILAMENT EXPLAINED AGAIN....HOPEFULLY A BIT BETTER Ok so I have a bit of time spare during my night shift so I thought I'd have another go at explaining how th
geert_2
Results before and after "acetoning". These are just old scrap pieces, which I kept around for testing. Material is colorFabb PLA/PHA, Dutch Orange. Printed with 0.4mm nozzle,
geert_2
Thanks for the info. So I will go the "cooking way", and just experiment. :) The shrinking might be a bit of a problem though, as the silicone castings should keep their shape and fit: th
Posted Images
cloakfiend 995
This is the finished model sprayed gold, spraying video in next post below.
![IMG_0925.thumb.JPG.17a1915d05a45d8b2903ee1cd9b2ebbc.JPG](//content.invisioncic.com/ultimake/monthly_2017_12/IMG_0925.thumb.JPG.17a1915d05a45d8b2903ee1cd9b2ebbc.JPG)
Edited by GuestLink to post
