Thanks for the reply!
I've attached some images below. The first model i've tried to make is of a tyre, which has lots of detail. The resolution of the ulti print seems to be poor, the pla was squirting out of the nozzle before the program even started to run, is this normal?
As you can see, the quality does not look like a 'fine' resolution I was hoping for, I will try the settings above!
Thanks
Sam
gr5 2,024
picture please. "runny" is not sufficient explanation. Click "gallery" on top left of this page, then "upload" then make a new posting and click "my media" next to smile icon.
I recommend you DONT use "high quality" but use "full settings" mode.
Start off with layer height .1mm. Bottom layer .3mm. 220C nozzle temp, 50C bed temp, print slow (say 30mm/sec). Use brim if parts are lifting off glass. Fan at 100% by 1mm (parts may look "runny" (whatever that means) before fans come on but if they come on too quicly the nozzle temp can drop too fast). Shell MUST be integral amount of nozzle width - so .4mm nozzle, .8mm shell is good.
Show photo - there' so many things that can go wrong with so many different kinds of models and issues.
