Posted · Infill failure
The speed isnt the problem im having. its that the infill is under extruding for whatever reason
    Try to print your infill with 50 or 60mm/s.
    Speed probably is your problem; you are printing the infill at 80 mm/s with a temp of 210. You will get better quality results if you keep all your print speeds the same, except for 1st layer where the 20mm/s you have is good. Of course for this model speed may be more important than quality for you.
