You definitely do not have to take any panels apart. First remove the bottom cover - it's held in by 2 screws. Then remove the old temperature connector and notice where it was connected. You will probably want to remove the 4 screws holding that board in place - the 4th screw head is *under* one of the motor covers so you should probably remove that also - to do so first push the bed all the way down. There is either one or two screws depending how old your printer is.
This should all be straightforward.
Now to run the new cable. I would probably just run it on the outside and tie wrap it. But some people use the old temp sensor cable to string through the new temp sensor cable (tape together, pull it through).
gr5 2,334
First of all you can get cheaper stuff from 3dsolex and good quality. Also please indicate what country you are in by setting that in your profile settings. It matters as to the answers of many questions.
Edited by GuestLink to post
