Dim3nsioneer 557
- Remove the blue clip at the bowden tube holder
- Push the bowden tube holder down
- Gently pull the bowden tube out of the holder
- Repeat the previous steps at the other end of the bowden tube
- Stick some long, non-brittle piece of filament into the bowden tube and push the fragment out
- Gently push the bowden tube back in the holder an make sure it is pushed to the very limit
- Fix the blue clip again
neotko 1,417
Push it out using filament through the bowden? If the filament isnt on the bowden but on the head. Get the head to 100-120 and take it out with a plier.
