I've had the BondTech on my Kossel delta for months. It just pushes the filament right, I really do like it, and it's a marvelous piece of engineering. So I decided to go for the BondTech on both of my UM2's.
- 1
I've installed the BONDTECH feeder last week. It works fine. The only issue I had in the beginning, was that the small Gcode program didn't SAVE the new E-step setting in the EEPROM (it worked just for one print). Using Tinkergnome's "Motion Settings" solved the problem. I think, the BONDTECH feeder is a better choice than the UM 2+ - extruder.
I Agree
I installed the Bondtech last week on my Ultimaker 2 extended and it is perfection! I also have a Ultimaker 2+ and am actually in the process of ordering a Bondtech for that as well. I only use XT for my prints and have not been able to tune my UM2+ to give me the quality I need: 0,25 nozzle, 0,04 layer height. The Bondtech just worked directly out of the box on my UM2 extended (after the recomended firmaware upgrade).
I measured the feeding of the UM2+ and got strange results since it retracted 1mm more then it fed?!? I extruded 100mm and retracted 100mm and it gave me this strange result constantly. Since my prints depend a lot on retractions and I do not have time too tinker with it now; I ordered a Bondtech. I am sure the fault is on my side, but right now time is money.
Edited by GuestHello,
I have some Problem with my Bondtech Extruder QR V3
(bought by https://www.freeform4u.de/bondtech-ultimaker-2-qr-extruder-upgrade-kit.html)
In the dokumentation, the e-steps are 492,45 but during tests to feed 100mm of filament, i have to readjust the steps to 511,79.
Now i Printed with Simplify 3d an rectangular thin wall test with 20x20x 15 and a wall-width of 0,45mm.
After printing i measured 0,8mm wallthickness and 20,4x20,35mm
I have used:
- a 0,4 nozzle (Orginal, no Olsson block, which has spent so far 33meters of PLA-filament)
- 0,2mm layerhight
- Vasemode
- Inofill PLA white with 220°C for first layer, rest 210° and 26,4mm/s printing speed.
- Labern Fan shroud with 100% fan speed
- Nozzle diameter in S3D is 0,4 and also the extrusion-width is 0,4mm
- extrusion-multiplier is 1.00
- Retract.-length is 5mm with 45mm/s and Retraction Vertical lift (=z hob) of 0,2mm
- Casting distance is 0,4mm and nozzle wipe distance is 5,0mm
Is this overextrusion caused by to high hotend-temperature and because of this a to strong material flow, or are the e-steps are to high? but with 492,45 e-steps i feed only 97mm (roughly).
or is it maybe related to the vase-mode?
Thanks a lot and warm regards,
Toni
Edited by GuestEsteps with bowden are a tricky thing. Because filament flex inside the bowden and you can't just push Material through the nozzle like a direct drive could. That's why that esteps you got are higher. (Anyhow there must be something weird on your esteps measuring because you should get less not more).
Anyway try to measure that pushing material through the nozzle and check how much filament was push.
More about the magic % missing
https://ultimaker.com/en/community/19330-esteps-and-ultimaker-o-and-the-magic-missing-10?page=last
Basically if too cood more compression on the bowden, if too hot little compression and less control. The good spot depends on what temps you want to calibrate (if you are aiming at the most perfect extrusion possible).
maybee i made something total wrong.
For evaluation of the e-steps, i put an older Bowdentube in an cut it to 101mm lengt.
Than i cut a 3mm (in diameter) steel rod and cut it to 99mm and put it into the bowden.
I moved the material (with the Thinkergnome-ware) into the bowdentube and pushed the rod close to the upper end of the bowden.
I left the rod 2mm below the cutted edge of my bowden. This is was my 0.
Than i moved the material 100.00mm up with the Thinkergnome-ware (during that, i pulled out the rod). I din't send any g-Code to the UM2 with the S3D-software.
After the 100.00mm has been shown on the display i measured the real length.
with 508,95 and 99,445 (average of 4 trys) i got 511,79 e steps.
I thought the formula is:
New e-steps= actual e-steps*(100mm (ordered length)/99,445mm (measured length))
Yea the problem is that filament doesn't extrude on a bowden like a steel tod. Try to measure 10cm (as a starting point) of extrusion at the temperature desired and extrude it at the extrusion speed you use.
Or easier. Mark the filament outside the bowden, heat to 200-210-220 (3 tests) and on each temp move 10cm off filament (move as in extrude). You will be able to actually see that at each temp the amount of filament moved is less/more by a small amount.
Also, you can just do estep calibration by eye.
Oh also and very important for estep calibration. All umo/um2/um2+ firmwares have a bug. Everytime you change esteps the immediate next move will be wrong. So, change estep, move 1mm, and then move 10cm (or the amount desired). But remember the first movement just after changing estep value will be absolutely wrong.
Top Posters In This Topic
13
12
10
5
Popular Days
Aug 21
13
Aug 6
9
Feb 16
7
Feb 17
4
Labern 13 posts
neotko 12 posts
ataraxis 10 posts
eldrick 5 posts
Popular Days
Aug 21 2015
Aug 6 2015
Feb 16 2016
Feb 17 2016
Posted Images
eldrick 65
P.S. - BondTech does offer a 1.75mm version.
