Hi Sander,
I already printed this 4 times and it is ALWAYS at the same spot. But it is definately NOT in the model. Also it is not a color issue - one can feel the step. Aktually it is even not like a notch or dent it is a offset. If you look at the first picture you can see the bottom of the print. So it starts printing slim and then we have a offset to slightly thicker - but on BOTH sides of the objekt.
Very strange I have no clue. It is just at a very certain spot where the printer has to print the bottm for the battery housing.
SandervG 1,499
Hi Coni,
It is a bit hard to tell from the pictures, is it more like a different shade of colour, is it an underextruded layer or is it more like a dent / notch?
If it is the latter, I am inclined to think it is in the model.
If it is underextruded there was most likely a brief moment of friction on the reel or in the bowden tube tube but it recovered. Colour gradient can happen because the temperature changed or something in the ingredients of the filament was different at that spot.
Have you printed this more than once? and did it occur at the exact same place?
