Going to the maintenance section where you manually set the temperature for the heated bed, whilst leaving it at 0 Degrees, I noticed the temperature reading was 24 Degrees. Not normal.
Maybe I miss the point but this seems perfectly normal to me.... assuming the ambient temperature of the room is 24 Celsius.
Did you check the PT100 separately? I mean just go into maintenance, to heat the bed (so you can read the temperature) leave it to zero and then heat it with an external source like a heardrier?
Ofcourse if you have a spare PT100 (like from the hot-end) you can also just stick it to the bed and test like this.
neotko 1,418
Sorry I can't help with this since my electrical knowledge it's just not enough. Maybe @gr5 or @dim3nsioneer can give you their input on this.
